I don't have the hardware to test this. I've been written a message for our staff members, but no reply so far.
I renamed the thread, and put it into Bug Reports sub-forum to generate more attention.
thanks
thanks
I found the issue.
On LE when I run ethtool eth0 it shows its only running at 100mb and not 1000mb. While on Pi OS its running at GB speeds.
I've just booted latest nightly on Pi4.
LibreELEC:~ # uname -a
Linux LibreELEC 5.15.61 #1 SMP Thu Sep 15 23:40:51 UTC 2022 aarch64 GNU/Linux
LibreELEC:~ # ethtool eth0 | grep Speed
Speed: 1000Mb/s
So I'm not seeing the issue on my network.
maybe it was fixed
maybe it was fixed
Can you update to latest and test again?
I set it to 1000MB/sec using ethtool and whenever I updated it it has not gone back.
So not sure if it was fixed or if the manual setting I did is still getting applied.
