LibreELEC settings for a RC6 remote control
  • Hello all,
    I have a small problem and hope to get help from more experienced people here.
    I have a HTPC running LIbreELEC and the connected RC6 remote works great. Also the Logitech Harmony One works very well here (unfortunately a bit delayed).
    So far everything is fine. :) :thumbup:
    I would like to take these settings that LibreELEC has made to my PC, since it is also equipped with an RC6 receiver. There, too, everything works perfectly under LibreELEC.
    I have tried to read into this topic, however, I am now more confused than before.
    Can I set up the settings on an Arch or Fedory system exactly the same as under LibreELEC? Is it enough to copy and replace configuration files? Is LIRC needed? /shrug
    It would be very nice if someone could help me here.
    Thanks in advance!
