I have started using the nighty builds a lot for testing and I mainly use libreelec as a PVR for FreeviewHD.
I have noticed that if I enable the DRMPrime decoder, any SD channel that is streamed at 544x576 resolution does not display video - either with or without DRMPrime hardware support enabled, though I can still hear the audio and the channel does continue to stream. Other HD and SD resolutions appear to work without issue. All streams do playback ok using VAAPI with MPEG2 HW enabled and DRMPrime disabled.
Is this just a limitation of the DRMPrime decoder that will eventually be updated to support bandwith friendly resolutions such as 544x576? or is there something I can do wih TVH streaming to output this correctly at 720x576 to allow these to play using the DRMPrime decoder?
