PI4 LE10 audio unsync using InputStream
Lauchsuppe  -
March 15, 2022 at 10:10 AM  -
Debug log may help.
But make sure desktop resolution is set to 1080p. Enable "adjust display refresh rate".
If you care about 4k, add hdmi_enable_4kp60=1 in config.txt and add modes you care about to display whitelist.
Also read through the info here https://github.com/xbmc/inputstream.adaptive/issues/877 - newer widevine versions cause high cpu load and stuttering, downgrade helps.
Thanks for your help. Downgrading fixes the problem.
