how-to add kernel module for allwinner H6 build
  • Hello I'm new on this forum , so perhaps it's not the good place .
    I would like to be able to use a USB-DVD drive, but it seems that with LibreELEC-H6.arm-11.0 release, the modules aren't present (sr_mod and some others).
    So is there a way to add it by building a new release with them ?
    Are there some links to explain it ?
    Thanks you :)
  • projects/Allwinner/linux/linux.aarch64.conf already contains CONFIG_BLK_DEV_SR=y, so CD ROM support is already enabled. It's built-in instead of module, but that doesn't make any difference. What other drivers are missing for your case?
  • Ok, I found the problem.
    It's when I insert a iso9660 cdom i have this output
    So i Tried a a manual mount et I have this oputput :
    busybox mount -t iso9660 /dev/sr0 /media/cdrom
    Output :
    mount: mounting /dev/sr0 on /media/cdrom failed: Invalid argument
    So perhaps the mount busybox version don't have the iso9660 fstype ?
    With a DVD it's Ok (udf fstype used ) and I can read the movie.
  • Hi, sorry for the late answer.
    Indeed it's included, but it was a mistake ...
    I tried to read an audio cd which isn't a iso9660 fs type.
    So i discovered that when i put a dvd in the reader it's the kernel that mount it with the udf fs type.
    But for an audio cd, it's kodi with a 'disc" icon where you can read or extract content.
    Making test i discovered that the problem comes from the USB3 port, sometimes the xhci-hcd driver seems not to manage correctly
    my usb-cd/dvd .
    With cubox, i solved the problem by blacklisting the driver (as a module) , but it seems to be a builtin and the blacklisting option
    has no action .
  • Yes, it's the "xhci-hcd" driver for USB3.
    Because it's seems that the driver has some problem to interact with my USB cd-DVD reader.
    I-ve got some messages like this one:
    reset high-speed USB device number 2 using xhci-hcd
    As it's a builtin module , it seems not to be easy to make it.
