after last update driver intel on windows i can do YCbCr 4:2:0 10-bit
what about for driver linux ?
LibreELEC-Generic.x86_64-11.0-devel-20211020222733-d3745e7.img.gz
This is from Oct. 20 master branch (Kodi 20) with the Atmos patch included.
Hi smp,
I think this link may be broken - do you have a link to your latest build?
Thanks!
The link should work now.
Thanks so much!
Hi smp, the download link for the HDR build is broken again. Can you, please, update it so I can try it too? Thanks!
Hi -
I am running a NUC8i7BEH, TV does not pick up video coming as HDR, same build on a NUC11 works and tv switches to HDR mode. Is there anything to look for in the logs, I can see the following:
2022-02-23 18:25:43.921 T:718 DEBUG <general>: CWinSystemGbm::SetHDR - setting connector colorspace to Default
2022-02-23 18:25:43.921 T:718 DEBUG <general>: CRenderManager::CreateRenderer - using renderer: vaapi
2022-02-23 18:25:43.921 T:718 DEBUG <general>: LinuxRendererGLES::Configure: fps: 23.976
2022-02-23 18:25:43.921 T:718 DEBUG <general>: CWinSystemGbm::SetHDR - setting connector colorspace to BT2020_RGB
2022-02-23 18:25:43.921 T:718 DEBUG <general>: CWinSystemGbm::SetHDR - display_primaries[0].x: 34000
2022-02-23 18:25:43.921 T:718 DEBUG <general>: CWinSystemGbm::SetHDR - display_primaries[0].y: 16000
2022-02-23 18:25:43.921 T:718 DEBUG <general>: CWinSystemGbm::SetHDR - display_primaries[1].x: 13250
2022-02-23 18:25:43.921 T:718 DEBUG <general>: CWinSystemGbm::SetHDR - display_primaries[1].y: 34500
2022-02-23 18:25:43.921 T:718 DEBUG <general>: CWinSystemGbm::SetHDR - display_primaries[2].x: 7500
2022-02-23 18:25:43.921 T:718 DEBUG <general>: CWinSystemGbm::SetHDR - display_primaries[2].y: 3000
2022-02-23 18:25:43.921 T:718 DEBUG <general>: CWinSystemGbm::SetHDR - white_point.x: 15635
2022-02-23 18:25:43.921 T:718 DEBUG <general>: CWinSystemGbm::SetHDR - white_point.y: 16450
2022-02-23 18:25:43.921 T:718 DEBUG <general>: CWinSystemGbm::SetHDR - max_display_mastering_luminance: 4000
2022-02-23 18:25:43.921 T:718 DEBUG <general>: CWinSystemGbm::SetHDR - min_display_mastering_luminance: 50
2022-02-23 18:25:43.921 T:718 DEBUG <general>: CWinSystemGbm::SetHDR - max_cll: 1000
2022-02-23 18:25:43.921 T:718 DEBUG <general>: CWinSystemGbm::SetHDR - max_fall: 362
2022-02-23 18:25:43.921 T:718 DEBUG <general>: LinuxRendererGLES::Configure: HDR passthrough: on
Fixed my issue, I have a TCL 55r615, had to change the hdmi input on the TV to use 2.0 (labeled as standard) :
Setting the HDMI® mode (4K models only)
On 4K (UHD) TVs, you can independently configure each HDMI® input to match the capabilities of the connected device. From the Home screen menu, navigate to Settings > TV inputs, and then select an enabled HDMI® input. Next, select HDMI mode
and then select one of the following settings:
• Auto – Let the TV determine the best setting. Use this option unless your HDMI®
device does not correctly communicate its HDMI® version compatibility.
• HDMI 1.4 – Configure the input for compatibility with HDMI® version 1.4, which supports a maximum refresh rate of 30 Hz at full UHD resolution. Most HDMI®
devices will work correctly with the TV in this mode.
• HDMI 2.0 – Configure the input for compatibility with HDMI® version 2.0, which supports a maximum refresh rate of 60 Hz at full UHD resolution. You must use this mode to view HDR content from the device connected to this HDMI® input. However, note that many older HDMI® devices do not work correctly when the TV’s HDMI® input is set to this mode.
Thank you SMP for this build!
