Control via Xbox Wireless Controller does not work
  • Hello all,
    I recently purchased an Xbox Wireless Controller (latest model).
    After I enabled Bluetooth on my Rpi 3 (LibreELEC 9.2.8) and connected the controller (the message says it's connected), however, I can't use it to control Kodi's menu.
    Do I need to install anything additional for this or do I need an adapter for this?
    The command using SSH unfortunately did nothing (Xbox One controller won't pair w/bluetooth (libreelec) : kodi and Xbox One Controller - Bluetooth
    echo 1 > /sys/module/bluetooth/parameters/disable_ertm
    If the controller is connected to the RPi via cable, everything works without problems.
    The old controller (XBox 360 controller) also works without problems using the corresponding adapter.
    Does anyone have an idea how I can get the current controller to work?
