How to configure Atric IR-WakeupUSB with RPi4
						JurKub
					August 16, 2021 at 2:46 PM
													Thread is Resolved
			your work around didn't work This one is working after the above console command but may not follow the rules of systemd Code: /storage/.config/system.d/lockdev.service[Unit] Description=Workaround for LIRC issue After=lircd.service [Service] ExecStart=/usr/bin/mkdir -p /var/lock/lockdev [Install] WantedBy=multi-user.targetHow did you find out, that the lock file is missing, are there any logs for lirc in libreelec? If you are looking for logs have a look at this folder: smb share: Logfiles or /storage/logfiles
			your work around didn't work A drop in file is injected into the systemd service. Check with systemctl cat lircd and systemctl status lircd. logging is usually done into journal. For lirc use journalctl -u lircd, for anything just journalctl.
			learned a lot the last couple of days  To not trust posted samples because they may contain typos?  Thanks, fixed my posts.
