Orange Pi 3 - irregular system freezing
  • I don't have an answer to that (yet).
    In fact, I customized your adjustments (made for LE11) for LE10.
    Never mind, now I've learned a bit about working with the diff utility.
    I will do some experiments and we will see which change is significant.
  • I made two new versions:
    V2 is without changing the CPU regulator voltage range and
    V3, on the other hand, contains only a change in the CPU regulator voltage range.
    First I tried V2. It ran for about half an hour and there was a system freeze.
    Then I used the V3 version. So far, it runs smoothly for about 2 hours. This looks promising, but we'll see in two or three days.
    Here is the contents of the V3 patch:
    Edited 3 times, last by LuRu (September 21, 2021 at 12:49 PM).
  • After a few days of daily use, I can confirm the previous conclusions.
    There are no system freezes. Only occasionally Kodi crashes (LibreELEC lives during the crash - it responds to a ping) and this happens always and only during IPTV playback. First the image stops and after a few seconds Kodi restarts.
    The significant factor is definitely the CPU regulator voltage range and not the wifi power supply.
  • Ok, thanks for confirmation. I also tested latest nightly image on brand new OrangePi 3 board today. I get exactly the same issues with the fresh board, so boards most likely work as they should.
    I'll PR fixes to master and LE10 branch as temporary fix. I have yet to figure out what to do exactly for upstream Linux.
