MEcool KII Pro s905d 2gb version, dead bricked, Purchase in 2020, Help Required
  • However, these commands are no longer necessary. I've already sent you another bootloader.
    Now install dtb as already described. Then install aml_upgrade_package.img.
    Edited once, last by bumerc (October 2, 2021 at 2:27 PM).
  • Please review and approve as i understand below steps to install image......
    Method 1 Steps to install stock android 7.1.2 image
    Preparation
    1 Prepare boot SD Card with new u-boot.sd.bin
    2 copy u-boot.bin
    3 Copy stock _aml_dtb.partition on sd card
    4 copy repacked stock android image, 02 nos files replaced (bootloader.PARTITION = u-boot.bin , aml_sdc_burn.UBOOT = u-boot.bin.sd.bin )
    Installation 1st Method
    5 Insert SD card in Box
    6 boot from Sd card by pin shorting Method pin 29 and 30.
    7 abort auto boot by pressing space key
    8 Run Commands
    CMD A
    store disprotect key
    store init 3
    CMD B
    fatload mmc 0 ${loadaddr} u-boot.bin
    store rom_write ${loadaddr} 0 100000
    CMD C
    fatload mmc 0 ${loadaddr} _aml_dtb.partition
    store dtb write ${loadaddr}
    CMD D
    run update
    Method 2 -- 2nd method (copy all partitions), if method 1 fails....
    Preparation
    2 copy u-boot.bin
    4 copy all partitions of stock android image with 02 nos files replaced (bootloader.PARTITION = u-boot.bin , aml_sdc_burn.UBOOT = u-boot.bin.sd.bin)
    Installation 2nd Method
    8 Run Commands
    CMD A
    store init 3
    CMD B
    CMD C
    CMD D
    N/a
    CMD E
    sdc_update _aml_dtb _aml_dtb.PARTITION normal
    sdc_update boot boot.PARTITION normal
    sdc_update recovery recovery.PARTITION normal
    sdc_update logo logo.PARTITIO normal
    sdc_update bootloader bootloader.PARTITION normal
    sdc_update system system.PARTITION sparse
    CMD F
    defenv_reserv -a
    saveenv
    reboot
    Edited once, last by s4shail: Merged a post created by s4shail into this post. (October 4, 2021 at 10:51 AM).
  • Method 1 Steps to install stock android 7.1.2 image
    No. Repeated unnecessarily.
    1. Write aml_upgrade_package.img on the mSD card with Amlogic Burn Card Maker.
    2. Copy _aml_dtb.PARTITION to the FAT partition of the mSD card and rename the * .ini file to * .ini.bak.
    3. Start the TV Box from this mSD card and write the * .dtb.PARTITION on eMMC.
    4. Remove the mSD card and rename the * .ini.bak to * .ini again.
    5. Now start sd card upgrade.
    P.S. In your case, the vendor uses the misc partition, which contains certain key signatures for certain applications. A manual installation of individual partitions does not help you, as the misc partition also has to be installed. Otherwise the stock fw will not run.
  • above Method fallowed
    WiFi Bluetooth still not working
    error system UI has stopped is flashing on screen again and again....
    edit
    In my observation, system UI stopped error comes when,
    "system first time initialization of app" not come on android first boot..
  • s4shail
    avc: denied { write } for pid=4700 comm="ndroid.systemui" name="property_service" dev="tmpfs" ino=8243 scontext=u:r:platform_app:s0:c512,c768 tcontext=u:object_r:property_socket:s0 tclass=sock_file permissive=0
    Sys UI
    Try to create a new rule for property_socket in sepolicy, allow write access to the sock_file:
    (allow platform_app property_socket (sock_file (open write)))
    and recompile sepolicy..
    WIFI
    [  111.636750@1] dhdsdio_download_code_file: Open firmware file failed /etc/wifi/4335/fw_bcm43455c0_ag.bin
    [  111.649276@1] _dhdsdio_download_firmware: dongle image file download failed
    Check that the /etc/wifi/4335/ directory contains the correct fw -> fw_bcm43455c0_ag.bin
  • checked
    files exists on path
    \system\etc\bluetooth\6255\
    BCM4345C0.hcd
    bt_vendor.conf
    \system\etc\bluetooth\4335
    bcm4335.hcd
    bcm4335_prepatch.hcd
    bt_vendor.conf
    4355 folder
    6255 folder
    auto_pairing.conf
    bcm4335c0.hcd
    blacklist.conf
    bt_did.conf
    bt_stack.conf
    bt_vendor.conf
  • Please can you help me ?I have the same problem. Can you please share your repacked img for usb burn tool
  • KII PRO Hybrid STB
    Hallo,
    is there someone from "DACH" or nearby Europe who can bring my bricked device back to life?
    I tried a firmware update. A logo or image appeared on the screen for a very short time. I couldn't see what it was. It was just a flash.
    From then on the device was completely dead. And hasn't done anything since. I have read all the tips here. But that's technically too high for me. And I would like to have someone do it who understands something about it and has already done it.
    ist hier jemand aus "DACH" oder dem nahen Europa, der mir mein gebricktes Gerät wieder zum Leben erwecken kann?
    Ich hatte ein Firmwareupdate versucht. Es kam ganz kurz ein Logo oder Bildchen auf dem Bildschirm. Was es war, konnte ich nicht erkennen. Es war nur ein Aufblitzen.
    Ab dann war das Gerät komplett tot. Und tut seitdem nichts mehr. Die ganzen Tipps hier habe ich zwar gelesen. Aber das ist mir technisch zu hoch. Und ich würde das gerne jemanden machen lassen, der davon was versteht und schon gemacht hat.
