Hello,
I'm a beginner with Raspberry and Libreelec!
These are my experiences with Libreelec 9.95.1 on a RPi 4B with an Armor case (EAN: 4251266701552) and an Astrometa USB stick (2014 revision Astrometa DVB-T2 - LinuxTVWiki) to watch DVB-C.
First of all, I also use(d) the stick on W7 amd W10 both pro (I think also W2k and XP) with ProgDVB. No complains at all.
My first try was with LibreELEC-RPi4.arm-9.2.6.img.gz. Didn't work at all, but that was probably my lack of knowledge ![]()
Setup for Libreelec 9.95.1:
Tvheadend HTSP Client 8.3.0.1
Tvheadend Server 4.2 9.80.11.125
All on default settings.
I couldn't connect to the server over web-if. Disabling and enabling the server fixed that problem.
Installation was smooth. Some minor problems, but I'm a noob.
Sound (stereo 3.5 jack): disturbances, interferences, drop outs, A/V sync problems, voices sound like helium driven (sound funny)
Video: HD so-so, SD remarkable interlacing artefacts (you won't watch that!)
Sky Sport News HD is the channel with the biggest data rate, receiving strength 55% and temperature 110°F ca. 44°C. CPU usage was low.
What can I change to make it better? Is the Pi too weak? My laptop (i7-3520M CPU @ 2.90GHz) is working pretty hard when watching above channel (but perfect sound and video with ProgDVB).
Ok, I just saw LibreELEC-RPi4.arm-9.95.2.img.gz is out. Does it make sense to try that one or should I give it a try with LibreELEC-RPi4.arm-9.2.6.img.gz?
Any suggestions are appreciated.
