I did hard reset and all is OK except I noticed I can't play DVDs ripped to iso on kodi 17 but I will post that somewhere else when I get chance.
Sent from my A0001 using Tapatalk
updated from a milhosue build from june.
The whole system seems a bit slow, what performance can I expext on a atom system with ion2 chipset?
Is there a frontend for retroplayer? I can start game from the filemanager, or did i miss something?
SNES had a lot of skipping sound.
Kodi is the frontend for retroplayer ![]()
You can try and speed things up by disabling rewind
settings --> game --> disable rewind
ic, thnx.
Is there no GUi with nice screenshots and stuff?
tried the RCB, but it seems its not made for retroplayer.
Not sure what you mean
Kodi is the GUI
You add a source that contains all your games, or you can use the IARL to browse roms from archive.org
Then you select a game and it launches with a specified emulator.
just a GUI that displays the titles with screenshots and other infos, maybe like this one:
mGalaxy | Features
Currently there is no scraper functions to "set content" yet. This will be added in the future.
Hello
Installation on my x64 was fine.
Question
How can i add a Rom? In the ain menu i see game section and add games. I add a folder with Roms. But i See no games
Bug?
I use profiles. If i want switch, LE freeze/crash
Hello.
I have a same problem as above user. When folder with roms is added I see no games.
Also, can I use wifi with this build? I see no trace of it in settings, and my dongle is just dead when system is booted.
I noticed there are wetek hub builds but no Core builds, will the official retroplayer release not support the Core?
Yes it will, it will support all builds.
These builds are dead now. Retroplayer has been merged into kodi master so soonish (a couple weeks) retroplayer will be built into LibreELEC master and into LibreELEC 9.0
