7.0.2.009 build for S905/S905X
    For my MI Plus box there are 2 big problems with sound:
    1. software sound mixing doesn't work correctly: if choose 5.1 mixing the central (voice) channel is missing (surround speakers are working). If choose 2.0 mixing all channels are mixing fine (but only in 2 channels!).
    2. Passthrow doesn't work.
    So, I can't listen the soundtrack on my reciever in proper fool channel mode. Works correctly only 2.0 mode.
    In stock firmware it worked!
    Can anybody help me a hint?
    Sergey.
    Edited once, last by kszaq (November 13, 2016 at 10:16 AM).
  • I want to buy new device, two choices:
    1. MINI M8S II.
    2. beelink MINIMXIII II.
    Someone has been using these devices and can give an feedback on it?. What about hdr it's work well (no problem with contrast level)?.
    Which one would you recommend?
    I using a wired network connection, so no worries about WiFi.
    Thanks in advance
    Edited once, last by quitroot (November 13, 2016 at 5:51 AM).
  • Apparently, there is better support for Mini M8S II hardware...
    Judging from others sources, none of s905x boxes do HDR well, as I described above... It does some conversion but the result is wrong...most likely an amlogic SDK problem
    Sent from my GM 5 Plus d using Tapatalk
    Edited once, last by mytbyte (November 13, 2016 at 8:15 AM).
    1. MINI M8S II.
    Hi
    I'm using a Mini M8S II (see my signature), and everything works :
    - 24p working flawlessly (using x264 / 8/10 bits x265)
    - optical / HDMI passthrough
    - IR receiver is very good, I don't have to point my Logitech Harmony directly to it
    The only minor issue is the suspend mode : if I wake up the device after a few seconds, it works.
    But I can't wake it up after a few hours.
  • So what you're saying it's actually a disadvantage that it's allowed by default.
    No... It doesn't matter, be it on or off (the results are different) both ways are wrong...if it's on, picture is washed out and pale overall, when it's on, the picture has more contrast but blacks are elevated...
    Edited once, last by mytbyte (November 13, 2016 at 8:54 AM).
  • Dear kszag,
    I've got Mini MXIII II (S905X). The seller send wrong version.
    I tried, your 009 version of LE, and I used this gxl_p212_2g.dtb (rename dtb.img). I found system/etc the remote.conf file and copy to the card root and LIBREELEC > Configfiles folder.
    The remote still not working. Under andorid working perfectly.
    Could you give me any advice? Here is the remote.conf file, could you check it?
    Thank you!
    Kind regards,
    Cold5
  • kszaq Thank you for your fantastic work! It seems that this build gives me problems with playing HD content. When the resolution > SD, scaling doesn't seem to work. Every HD stream/file I play looks like it's zoomed in. I do have the correct DTB (checked twice and installed via dd if=dtb.img of=/dev/dtb bs=265k). Could this be related to the 4k scaling patches in the most recent changelog, or did I miss anything?
    Edit: Using TX3 Pro, S905X, 1GB Ram
    Edited once, last by J.stam.84 (November 13, 2016 at 10:13 AM).
  • kszaq
    I've moved my portable usb DVD drive from rPi 3 to A95x (s905). At rPi i had play dvd in main menu, but a95x does not show it up. lsusb shows that device was discovered but no automount was executed.
    Any solution to this problem?
  • I need help with enabling wifi chip on my Beelink Mini mxIII II...I read above that some of you have been successful, but I myself can't get it to work...
    I installed the latest LE build from the first post that is supposed to have some experimental Aigale support, I created autostart.sh in Configfiles via samba (also did ssh to confirm, Configfiles seems to be the same directory as .config), pasted the lines from the first post, rebooted, but wifi and bluetooth are still unavailable...can anyone please give some quick step-by-step? Also I understand that I don't need any specific device tree files for s905x, right?
    Also, can anything be done with the wrong HDR to SDR conversion (blacks are elevated - gray, and gamma is crushed) and BT.2020 to rec.709 conversion? there is a "deep color" option in Android 6.0 display settings that enables bt.2020 support but only as HDMI metadata for the UHD TV to render it properly, it does no colorspace conversion for non-UHD TVs, but something like that would be welcome in LE if at al possible...these are 4K boxes after all :rolleyes:
    Im having the exact same problem. I created the autostart.sh file. With file ending in .sh NOT .txt or .py and placed it in the .configs folder. rebooted and cant see my wifi. Any help is appreciated.
    Please collect logs and head over to this thread: LibreELEC
    Remember that these drivers are experimental and I don't have device to test. Also I don't think that Bluetooth will work.
    There is a way to disable hdr on libreelic?.
    echo 0 > /sys/module/am_vecm/parameters/hdr_mode
    Apparently the file is not correct for the remote you have. You may want to look for other files with remote in the beginning and conf at the end, like remotesecond.conf. Rename in to remote.conf, copy to Config folder and reboot.
    Has Xtreamer stolen kszaq's work?
    Xtreamer mxV = K1 Plus
    http://forum.xtreamer.net/topic/40109-xt...tallation/
    Using GPL code to create your own project is not stealing and everybody is free to do it as long as they share source code after modifications.
    It might be scaling issues and you missed posting logs. ;)
  • Ok, dvd is discovered but after menu i got some error:
    [code=php]
    11:40:51 T:545582887136 NOTICE: Creating InputStream
    11:40:51 T:545582887136 NOTICE: DVDPlayer: playing a file with menu's
    11:40:51 T:545582887136 NOTICE: Creating Demuxer
    11:40:51 T:545582887136 WARNING: could not find codec parameters for /dev/cdrom
    11:40:51 T:545582887136 NOTICE: Opening stream: 0 source: 512
    11:40:51 T:545582887136 NOTICE: Finding audio codec for: 0
    11:40:51 T:545582887136 ERROR: Unsupported audio codec
    11:40:51 T:545582887136 ERROR: OpenStream - Unable to init overlay codec
    11:40:51 T:545582887136 WARNING: CDVDMessageQueue(audio)::Put MSGQ_NOT_INITIALIZED
    11:40:51 T:545582887136 WARNING: CDVDMessageQueue(video)::Put MSGQ_NOT_INITIALIZED
    11:40:51 T:545582887136 NOTICE: Opening stream: 0 source: 256
    11:40:51 T:545582887136 NOTICE: Creating video codec with codec id: 2
    11:40:51 T:545582887136 NOTICE: Creating video thread
    11:40:51 T:545582887136 NOTICE: Opening stream: 2 source: 256
    11:40:51 T:546056433888 NOTICE: running thread: video_thread
    11:40:51 T:546056433888 NOTICE: fps: 0.000000, pwidth: 720, pheight: 576, dwidth: 1024, dheight: 576
    11:40:51 T:548298096640 NOTICE: Using GL_TEXTURE_2D
    11:40:51 T:548298096640 NOTICE: GL: Selecting Single Pass YUV 2 RGB shader
    11:40:51 T:548298096640 NOTICE: GL: NPOT texture support detected
    11:40:53 T:545582887136 NOTICE: CDVDPlayer::OnExit()
    11:40:53 T:545582887136 NOTICE: DVDPlayer: eof, waiting for queues to empty
    11:40:53 T:545582887136 NOTICE: Closing stream player 2
    11:40:53 T:545582887136 NOTICE: CDVDMessageQueue(video)::WaitUntilEmpty
    11:40:53 T:545582887136 NOTICE: waiting for video thread to exit
    11:40:53 T:546056433888 ERROR: Got MSGQ_ABORT or MSGO_IS_ERROR return true
    11:40:53 T:546056433888 NOTICE: thread end: video_thread
    11:40:53 T:545582887136 NOTICE: deleting video codec
    11:40:53 T:545582887136 NOTICE: Closing stream player 3
    11:40:53 T:548298096640 NOTICE: CDVDPlayer::CloseFile()
    11:40:53 T:548298096640 NOTICE: DVDPlayer: waiting for threads to exit
    11:40:53 T:548298096640 NOTICE: DVDPlayer: finished waiting
    11:40:55 T:548298096640 ERROR: Unable to activate the previous window
    [/php]
    Also i see that aml_grabber for hyperion does not work good. There is a lot of errors in log. At current state rPi 3 is better machine for complex setup :/
  • Im having the exact same problem. I created the autostart.sh file. With file ending in .sh NOT .txt or .py and placed it in the .configs folder. rebooted and cant see my wifi. Any help is appreciated.
    Did you create the file using a Windows editor, with the Samba share ?
    If so, can you login with a SSH client, and issue a "dos2unix /storage/.config/autostart.sh" ?
  • Did you execute
    chmod ugo+x ./autostart.sh
    ooops, I just did what you suggested and I got wireless working after reboot!!! I guess execute permission was not set far all users?
    I only needed to dectivate then re-activate to show available wifi networks! Bluetooth sadly not working...yet ;)
    Thank you
    P.S. kszaq: I suppose we can't get the manual for available am_vecm parameters and what they do exactly? One would need to aquire amlogic's SDK?
    Edited once, last by mytbyte (November 13, 2016 at 11:51 AM).
