python script not executed automatically
  • I installed libreelec using image
    Thesystem boots automatically into KODI.
    if i login over ssh with MobaXterm 20.6 i see:
    LibreELEC (official): 9.2.6 (RPi4.arm)
    LibreELEC:~ #
    So I would like to control my ambilight at the same time via hyperion.ng
    In order to shutdown the Raspi automatically when switching off power
    I use the hardware extension "StromPi3".
    Therefore a python script ("powershutdown_serialless.py)must be
    executed when starting up the Raspi.
    In the forum I found the post by "jakob" from June 13, 2020 and then made all
    the settings :
    - install "Raspberry Pi Tools" add-on
    - create the folder /storage/.kodi/userdata/scripts
    - insert lines in my powershutdown_serialless.py
    import sys
    sys.path.append('/storage/.kodi/addons/virtual.rpi-tools/lib')
    - put powershutdown_serialless.py into /storage/.kodi/userdata/scripts
    - create /storage/.config/autostart.sh
    both files attached in the datei.zip.
    When i start the powershutdown_serialless.py from an ssh terminal see hier :
    LibreELEC:~ #
    LibreELEC:~ # python /storage/.kodi/userdata/scripts/powershutdown_serialless.py &
    LibreELEC:~ # Safe Shutdown in the case of Powerfailure (CTRL-C for exit)
    it works fine. But on booting the raspi the script "powershutdown_serialless.py"
    is not executed.
    Where is the mistake ?
    many thanks for the support
  • Check your autostart.sh script if you just created it for any errors DOS format and not UNIX?
    this should start your script like on startup..
    sh /storage/.config/autostart.sh
    run this on autostart.sh
    dos2unix /storage/.config/autostart.sh
    chmod 777 /storage/.config/autostart.sh
    the autostart.sh in your zip file is in windows dos...needs to be unix format..but might have changed by uploading or downloading or whatever..not sure...try those 2 commands and you should be good to go..
  • the problem was definitely autostart.sh
    I logged in with a terminal program (mobaxterm) and the /storage/.config/autostart.sh file was just one line
    created and the rights set with chmod.
    the command is now executed correctly. after entering ps -ef i can also see the running process. 566 root 0:00 python /storage/.kodi/userdata/scripts/powershutdown_serialless.py
    it would be nice if a message could be sent to all logged-in terminals in the event of a power failure - is that possible?
    the print commands from the powershutdown_serialless.py script do not arrive on a logged-in terminal
    Many Thanks
    Edited once, last by aldebaranhg (February 11, 2021 at 2:59 PM).
  • try before line 50 in your script add
    os.system("echo "Raspberry Pi Shutdown!" >/dev/pts/1")
    that is for 1 open terminal
    if you have more then
    to find all open terminals
    find /dev/pts
    then you can edit your script ex
    os.system("echo "Raspberry Pi Shutdown!" >/dev/pts/2")
    os.system("echo "Raspberry Pi Shutdown!" >/dev/pts/3")
    etc
    that should send a message to all terminals
    Edited 3 times, last by Mario77 (February 11, 2021 at 7:42 PM).
  • thank you for your prompt reply
    Unfortunately I don't get any output on my terminal (MobaXterm via ssh)
    when I insert the new line:
    if x> = ShutdownTimer:
    print ("Raspberry Pi Shutdown!")
    os.system ("echo" Raspberry Pi Shutdown! "> / dev / pts / 1")
    time.sleep (5)
    os.system ("shutdown -h now")
    the modified script is no longer executed - no display of 687 root 0:00 python /storage/.kodi/userdata/scripts/powershutdown_serialless.py
    more about the processes at ps -ef
    I also tried to add a waiting time so that the message could be read, but it didn't work either.
    Edited once, last by aldebaranhg: another test (February 11, 2021 at 8:44 PM).
  • additive
    sh /storage/.config/autostart.sh results in:
    LibreELEC: ~ # sh /storage/.config/autostart.sh
    LibreELEC: ~ # File "/storage/.kodi/userdata/scripts/powershutdown_serialless.py", line 51 os.system ("echo" Raspberry Pi Shutdown! "> / dev / pts / 1") ^
    SyntaxError: invalid syntax
  • additive
    try copy and paste this exactly..
    below is yours...you moved few bits:
    It worked here...no reason it doesn't work for you...you can open more terminal windows to test from one to the other and you ll see the message popping up..
    I m not great with python hence i gave you the shell version of the command..you r basically sending an sh command from a py script..
    I m not sure what your script is for but if it's something important you can even send an automated email from libreelec to your email..
  • i copied the code exactly. Maybe some characters (space) got into it through later editing (google translater).
    Sorry, I still have to learn how to correctly compose my posts!
    I think the python interpreter cannot recognize the expression os.system..... The normal shellcommando
    LibreELEC: ~ # os.system ("echo" Raspberry Pi Shutdown! "> / Dev / pts / 0")
    sh: syntax error: unexpected word (expecting ")") does not work under Libreelec either.
    with LibreELEC: ~ / .config # echo "3456"> / dev / pts / 0
    3456
    can I send texts between logged-in terminals.
    to your question:
    the script powershutdown_serialless shuts down the raspi at power off. That works fine. I can also do without the additional issue of a message.
    when I start the script manually:
    LibreELEC: ~ / .kodi / userdata / scripts # python powershutdown_serialless.py &
    LibreELEC: ~ / .kodi / userdata / scripts # Safe Shutdown in the case of Powerfailure (CTRL-C for exit)
    Here you can also see that the script is working properly:
    messages are issued.
    Case 1 momentary power failure
    LibreELEC: ~ / .config # Raspberry Pi Powerfail detected
    Raspberry Pi Power Back Detected!
    Case 2 long failure power
    The main thing is that the script is started automatically and works properly.
    Thanks again :)
