since the build "LibreELEC-RPi2.arm-9.80-nightly-20201116-df2a079" I have a very loud TV sound when booting up, it stays around 1-2 min.
Log : ix.io/2FHG
Log : ix.io/2FHG
What type of sound? From an actual TV channel, or just some random loud noise?
I had de-installed the addons, no success, the sound came back when I booted.
I did a new installation with the "LibreELEC-RPi2.arm-9.80-nightly-20201121-1e75df4.img.gz" and the sound is gone.
But I couldn't make WiFi settings with this version, so I first had to install "LibreELEC-RPi2.arm-9.2.6", make WiFi settings and then update to the nightly.
Now everything is going well, the sound is gone, without addons.
If I change the resolution of the surface (1080i ..) then the loud long sound comes back, with a now clean system without addons.
When I try to fast forward a video file, the loud sound, black screen and that's it.
I give up and go back to V18 there everything is ok
You do know that errors/bugs are not solved magically on their own, right?
But for now you were the only one hearing weird noises, so I guess we're all good.
Today I have the version from November 29th. tested and it looks better. No loud sound and I can fast forward the videos, so everything is ok.
It wasn't an update I installed the img.gz maybe it was because of that.
I still can't make the WiFi settings.
