Again IR remote questions
  • Hello,
    if i use the command ir-keytable i see 2 devices
    How can I select the iMon Remote to use with ir-keytabel??
    I tried
    ir-keytable -v --device= /dev/lirc1
    but got
    Unable to query evdev protocol version: Inappropriate ioctl for device
    how to use it correctly??
  • With ir-keytable you have to specify the rc device, "rc1" in the case above, using the "-s" option. eg ir-keytable -s rc1 ...
    Note that the rc device numbers may change across reboots so always check with "ir-keytable" before.
    In rc_maps.cfg you can match by driver name, that's the first entry. eg
    imon    *    my-keymap
    That being said, using the nuvoton CIR would be a better choice (if it has an IR receiver connected) as it supports more protocols - the imon receiver is quite limited...
  • Hello,
    Yeah the nuvoton CIR is behind the alumnium body therefore a little bit tricky unfortunately....
    How do I change the protocol of the imon to rc6?
