Hi everybody, just updated from 9.2.0 to 9.2.4. Had some problems with librespot (missing dependency), but that worked out now.
Using RPI3 as hardware. Sound is fine with HDMI. But in 9.2.0 I just used the HiFimeDIY Audio SA9023 USB Audio as primary output. And if I recall it correct, I could just select this device as main output device in the System options of Kodi and had to do nothing via SSH.
But with 9.2.4 I do not have a chance to get the sound working. Has anything changed? I read the blogposts, but came across nothing. Spent the last 3 hours searching the net... but had no luck
I am a bit into Linux, but not so much into drivers/sound. So dmesg states it finds the device:
[ 2.053780] hid-generic 0003:262A:10E0.0001: No inputs registered, leaving
[ 2.053993] hid-generic 0003:262A:10E0.0001: hidraw0: USB HID v1.00 Device [HiFimeDIY Audio SA9023 USB Audio] on usb-3f980000.usb-1.2/input0
But lsusb -t does not show any driver:
|__ Port 2: Dev 4, If 0, Class=H uman Interface Device, Driver=usbhid, 12M
|__ Port 2: Dev 4, If 3, Class=Audio, Driver=, 12M
|__ Port 2: Dev 4, If 1, Class=Audio, Driver=, 12M
I found some other forum entry, who is using the same chipset I guess: Sabre USB DAC SA9023 problem - Raspberry Pi Forums
So I thought I had to manually load snd-usb-audio. modprobe snd-usb-audio is just not working:
So I stumbled upon the wiki Raspberry Pi Config.txt [LibreELEC.wiki] and tried some dtparam and dtoverlay entries in config.txt - no luck either.
Is there an readme or something else, when to use which overlay?
pactl list does not show my device either, but only the default Kodi ones, but guess this is because the driver is not loaded.
Soooo, has anyone a clue or tip for me? I am stuck now
Or anything else I can provide? The kodi.log seems fine, journalctl just keeps informing me with this:
