Don't think its just me having tried this on a second Pi...
I just upgraded a couple of my PoE powered Pi 3b+'s already fitted with PoE hats to 9.2.3. Everything seems to work as expected with the following exception...
The Pi appears to ignore the
dtparam=poe_fan_temp0=65000,poe_fan_temp0_hyst=5000,poe_fan_temp1=67000,poe_fan_temp1_hyst=2000
entry in config.txt. the fans are still firing off at 50° not the 65° specified.
My previous LibreELEC release (9.2.1) worked exactly as expected with the fan cutting in at 65°
Any Ideas?
