Unfortunately the redirects have not been set yet on the community server and it's nothing I can do about it, sorry. You need to wait a few days.
- kszaq
- Thread is Unresolved
How do I know if they were redirected?
mikmatcr Addons should work now.
ok, Later I try. Thank you
Now if the Libreelec repository works but it does not allow to install pvr clients. Everyone gives an error. What can be?
Hi there!
Is there any chance that you'll be creating a Kodi 18 update or perhaps a tutorial on how to update Kodi and compile? Your kernel for the MXQ is the best and I've been trying to figure out how to update the Kodi packages without success so far. If there's a basic checklist on what to do to pull newer Kodi into as a package, that would be amazing!
Thanks a ton!
Hi there!
Thanks a ton!
Kodi 18 is available from AlexELEC-S805.MXQ_V20.arm-3.1.8.tar
Does anyone have a mirror of these builds? near impossible to find now.
You mean kszaq's old builds or the continuation of his builds updated by AlexELEC?
Thanks for the response! Unfortunately none of these builds work with Bluetooth, including the MK808 build (My device is the Mk808BPlus)
The following build compiles as "MXQ" and works perfectly with my device with Bluetooth and everything, but its an outdated version of Kodi (17): GitHub - kszaq/LibreELEC.tv at 8.2.3.1
My goal is to get the latest version of Kodi running with the 8.2.3.1 kernel or fix the BT issue in AlexELEC - either would be great. Any help would be extremely appreciated. I would be willing to donate to fix the BT issue with the AlexElec build. I have a bunch (almost 100) of these MK808B+ sticks so fixing bluetooth has value to me. Just don't know who to go to for help with it.
Do you mind sharing that build? Also have an mk808b+ and just need any version with working bluetooth and wifi.
It's from the OP: Index of /s805/8.2.3.1/
Use the MXQ img, it's compatible with the MK808B Plus for Wifi and BT.
