I have problems writing the new image for my raspberry pi 2
I downloaded the new creator tool with the new image. Select the right Image.
I click destination and write, goes up to 93 percent and i got an error message which crashes the program.
I noticed I have two partitions on one SD so I used my other which was still in te Raspberry 2. I wiped it and same problem happened
1 partition is F: 512 mb and the other is G: with 6,4gb its an 8GB Micro SD card.
