Can someone help me to fix the "enter/confirm" button that stop working after addon Super Favourites was installed.
Rii Mini i7 problem with LibreElec
2469  -
February 18, 2020 at 4:59 PM  -
- Official Post
Please provide a full debug log.How to post a log (wiki)1. Enable debugging in Settings>System Settings>Logging2. Restart Kodi3. Replicate the problem4. Generate a log URL (do not post/upload logs to the forum)
use "Settings > LibreELEC > System > Paste system logs" or run "pastekodi" over SSH, then post the URL link -
Hello and thanks so far. I will fix a log during the weekend though i work a lot right now... A question before i make the log dump, do it rerecognize a "dead" button when i push it? Or should i make something before so you can see the problem? I have an almost clean install of LE and what i mean with almost is that i have use it for a while(1-2 monts).. Take care/Thore from Sweden
I found the solution by my self... I wait to hear from you so i look and found the help elsewhere...
