Hello all Libreelec user and Libreelec team !
First of all thank you for all the work accomplished ![]()
I encounter some problem with my Xbox One controller paired in bluetooth : input are not recognized under LibreElec.
The controller is well paired and input are detected under btmon but not with Kodi (under Input devices menu when trying to map controller)., except the "Home" button.
There's no error in log and using the xpadneo driver instead of xpad doesnt help.
I cant figure out where the problem is comingfrom (my knowledge is not sufficient).
This seems to be only related to LibreElec since when installing Kodi on raspbian or using it with other distributions (recalbox), there's no such problem.
Any clue ?
My hardware and software setup :
> Raspberrypi 3B+
> Xbox One controller (v1708) connected via onboard bluetooth
> Libreelec 9.2 (fresh install, no addons and all settings set to default)
> ERTM bluetooth mode is disabled to allow pairing of the Xbox One controller (/sys/module/bluetooth/parameters/disable_ertm set to 1)
Other threads related :
