The sources for the DTS build are in GIT ArmbianTV.
Thank you. I will look into this.
Ver 20230404 kernel 6.2.9
Ver 20230413 kernel 6.2.10
add image for Firefly Station P1 Pro (rk3399 + NVMe)
QuoteDisplay MoreLibreELEC-ARMv8.aarch64-11.0-devel-20230111091039-e014594-rk3399.img
Hello! Very big thanks for your work!
I am using this image for my orange pi 4 lts and it have 10/100/1000Mbps Ethernet ( YT8531C )
is any way to add this support in your image or i can do it myself using some instructions?
Testing on orange Pi 4 lts 3GB ram \ 16GB EMMC RK3399-T
Working
-Mpeg2, H264, h265(hevc)
-HDR 10 bit
-4k 60fps
-video up to 200 mbit\sec
Not Working
-LAN (YT8531C )
-WIFI (CDW.20U5622-00)
-BT (CDW.20U5622-00)
Can you tell me from where to download that img??? Or at least the link.
thank you
Good morning.
I finally got the image. at least it can be used and the screen resolution is good.
The issue of the network is solved with a USB Wifi and a cable with a 3.0 Ethernet Hub.
The problem that I have in particular is that I can NOT play the torrents.
Both Elementum and Torrest give problems. How to solve this????
Thank you
The exact name of the image and model of your equipment, a detailed description of the steps.
El nombre exacto de la imagen y modelo de su equipo, una descripción detallada de los pasos.
Orange pi 4LTS
You should use the arm version (not aarch64), the aarch64 version has limited addon support.
Ok Thanks
Will any usb wifi adapter work? Or is there just certain ones that will? Thanks for any info.
Ver 20230428 kernel 6.3
Ver 20230519 kernel 6.3.3
Ver 20230522 kernel 6.4-rc3
Ver 20230608 kernel 6.3.6
Ver 20230609 kernel 6.4-rc5
