H96 MAX RK3399 problem AC3 audio
  • Guys I have a H96 Max RK3399 on which I am using the "rom" PINE64 RockPro64, it works very well except for the audio ... I have a problem with the reproduction of AC3 audio and its transcoding, someone knows how to solve this problem ??
    In HD audio I don't even hope on those devices anymore but under android the DTS and AC3 audio worked properly so it's not a problem of basic settings
    I could easily use also kodi on android, the problem is that every now and then it gets jammed and resets my information or I have to reinstall everything ... librelec would be a pleasant solution to the problem but the audio doesn't work properly: /
