LE9 - System Info stopped working from the remote as it did in LE7
  • I use LE7 on all my RPis. Just installed LE9 to RPi4. On, LE7, I would invoke "System Info" with a certain key of my remote whe the main Menu is displayed. Not, this does nothing. I copied my config to LE9 and all other keys seem to work as on LE7. I am primarily interested to see the Temperature. If I could burn it into main skin, I would like that even better.
    I am thinking: at LE9 the skin is changed and there lies some catch. I did install Confluence, so I do have the same looking skin on LE9.
    I am unable to find what to assign to my remote key. I do not have a problem redefining a key on my remote, I just need to be told what to stick to it to display System Info while in Kodi in Main menu.
    It looks to me like I need (to add to) global:
    <info>ActivateWindow(SystemInfo)</info>
    but it makes no change. Plus, I did not have this in LE7 and key <info> calls System Info with no problem.
    Edited once, last by pila (September 13, 2019 at 4:14 PM).
