My remotes work perfectly. I want to get 2 different Kodi devices in the same room, both using the same GPIO IR sensor and RC6 commandset to not recognize remote control intended for the other device. I can program anything into a Logitech Harmony remote. Now I am using Microsoft Media Center PC (Windows Media Center SE) commandset for a remote.
I can change remote definition for one RPi to use e.g. Philips RC-153 (Media center remote) but how to tell to the LIRC (or Kodi) in that RPi it should recognize only Philips RC-153 and not Microsoft Media Center PC (Windows Media Center SE)?
IRW shows commands only from remote A, ignores the rest. Killing lircd and trying with mode2 -d /dev/lirc0, I can see remote B (or any remote) is being read. So, I need a simple way to tell to the LIRC that I want it to use some other remote. I presume I should do it using lircd.conf. I would not like to have to define every keypress. Just say: use different remote using the same standard. Each keypress has encoded which remote is sending it, so a Panaonic and Philips RC6 codes are not be the same.
I can change remote to anything, if needed, As I am dealing with a pure IR sensor (not some finished product), I guess it recognizes anything, not neceserily only RC6.
