i am using LibreElec on a normal pc with a MCE usb IR receiver and a Harmony 950 remote.
I have added a Microsoft - Media Center SE device. The device is working except for the power toggle button.
Any ideas how to get this button working?
I tried 2 different MCE usb IR receivers and get 2 different results for the power functions. Here is the one I'm using now:
Genuine HP Infrared IR USB Receiver Sensor 5188-1667 12ft cord OVU400103/00 787805273777 | eBay
By the way, I'm using a Harmony 650 with the Microsoft Media Center Extender profile
but all the eHome IR Microsoft receivers all pretty much the same if i am not mistaking?
But you think the problem is the IR receiver?
I use this one:
Microsoft Media Center USB IR Receiver MCE Model 1040 for 1039 Remote | eBay
I never tried that one, so I can't say for sure. I can only tell you my experience using 2 completely different MCE usb IR receivers.
By the way, my Harmony 650 has a "power" button but "power toggle" is a display function when pressing the "devices" button and then selecting your device.
You do know you can assign unused buttons to almost any function you want, don't you ?
well i tried to assign power off to a button. But then it looks like the machine just does a hard power off. When i turn the machine back on, by hand because the power ON assigned button is not working
the sound is not working anymore and i have to reselected the HDMI sound port.
So yes power off is sort of working but the problem is the power on...
You meant by the Add-on Keymap Editor right?
I have 2 old Intel NUC's and cannot use "power on" for either because of the way they were built. So, I use the kodi "suspend" function instead and that works just fine for me. I suspect that may be your issue too.
Yes, I meant the Keymap Editor addon. Navigating and saving can be difficult at first.
