Banana pi m2 zero has h2+ orange pi lite was h3 cpu if U have on moment and can give me a litle help i will be very gratefull!
Banana pi M2 h2plus has 1gb of ram and h2+ cpu I think!
- jernej
- Thread is Unresolved
If you re-read my post you'll see which file to change. Once you open it, it should be very obvious how to change it - board name - dts file name - U-Boot config name
I tried that i wont boot black screen on banna pi m2!
This can only be debugged through serial console.
I cant do that if you help me
Note that with unsupported boards/features I only give clues here and there. I expect that anyone who works on that has sufficient knowledge to do it mostly on his/her own, unless if I think that it should be added to official LE but that is not the case here.
very strange, but since february i have problem with hdmi-audio output. Cubieboard2 nightly images. From the settings available only pcm and bluetooth. last work hdmi-audio for me is selfbuild LibreELEC-A20.arm-9.80-devel-20200202081811-2f50060-cubieboard2.tar
log Ubuntu Pastebin
lines 256 detect sun4i-hdmi but then line 495 list only PCM and bluetooth (i use usb bluetooth dongl)
this part kodi.log with working hdmi-audio
LibreELEC (community): devel-20200202081811-2f50060 9.80, kernel: Linux ARM 32-bit version 5.4.16
Kodi (19.0-ALPHA1 Git:6e15fcb9ff05ed7463d69083b2fa2fd702f3abd0)
Kodi compiled 2020-01-31 by GCC 9.2.0 for Linux ARM 32-bit version 5.4.16 (328720)
All next test.libreelec.tv images without hdmi-audio for me.
PCIe is not yet supported on H6 with mainline kernel, so it doesn't matter much. Are you sure that it doesn't use SDIO interface?
How can I check?
I don't know, open box and google wifi chip markings...
Hello, in "Orangepi Pc" I want to install Libreelec. I am looking for a current and stable version. Where do I find the image? Thank you.
I see that there are nightly and devel versions, which one to choose if there is no stable?
There is no stable version yet. It will come with LE 10 (no ETA). Just use nightly image, which is updated every day if there is any change.
find first broken hdmi-audio test image.
LibreELEC-A20.arm-9.80-devel-20200202081811-2f50060-cubieboard2 hdmi-audio work
LibreELEC-A20.arm-9.80-devel-20200215132138-d1fdc57-cubieboard2 hdmi-audio not work
this is not a very large interval to find out the reason?
well, there is quiet a lot commits: Comparing 2f50060...d1fdc57 · LibreELEC/LibreELEC.tv · GitHub
I suspect kernel update but it could be also something else, something indirect, like switch from binary mali driver to mesa (due to memory, for example)
I can try different images to localize the problem. There is no way to build images
What do you mean "there is no way to build images" ? Just checkout one of the intermediate commits and build it.
