problem installing "Pi tools" addon
  • Hello,
    I'm trying to install a Shutdown buttons to my Raspberry pi 3B, I followed a few forums and here is what I did;
    1. mkdir /storage/.Scripts
    2. nano /storage/.scripts/shutdown_pi.py
    In "/storage/.scripts/shutdown_pi.py" I have the following instructions;
    3. nano /storage/.config/autostart.sh
    in "/storage/.config/autostart.sh" I have the following instructions:
    python /storage/.Scripts/shutdown_pi.py
    3. I went in the libreELEC UI and did the following;
    Program ---> Get more ... ---> Raspberry Pi Tools ---> install
    4. reboot
    when I tested the buttons nothing happened so I tried;
    LibreELEC:~/.Scripts # python shutdown_pi.py
    here is what I got:
    Traceback (most recent call last):
    File "shutdown_pi.py", line 5, in <module>
    import RPi.GPIO as GPIO
    ImportError: No module named RPi.GPIO
    Is there a step I forgot?, or is there another thing I need to install?
    Thanks for your help.
  • you'll need to add the path
    at the top of your script you will need something like
    import sys
    sys.path.append('/storage/.kodi/addons/virtual.rpi-tools/lib')
    or something similar, I can't remember the exact path
    import sys
    Thank you,
    I no longer have " ImportError: No module named RPi.GPIO".. and when I do, " LibreELEC:~/.Scripts # python shutdown_pi.py" it stops and waits, which is what it is supposed to do.
    but when I press the button nothing happens... I even tried after reboot...
    Tomorrow I'ill have a look and see if the wires are connected correctly (I mean it's kind of late right now, where i' am at),
    I believe all the wires are connected correctly, but just to make sure I'll have a look (but tomorrow not now :P ).
    Anyway now I think I have a problem with the autostart.sh file... I must admit that I didn't fully understand the instruction, and I'm pretty sure that I messed it up somehow... so a little help on that front would be nice. (tuto I used is: Autostart.sh - OpenELEC )
    I know the code in " shutdown_pi.py " works since I used it on a Rpi 2B with a Raspbian OS, the only difference is the autostart.sh part...
    ps: You are right for the path (it is not similar, IT IS: ('/storage/.kodi/addons/virtual.rpi-tools/lib'), thought you should know you remembered right :D .
  • Only thing I can see wrong is that you change the use of "scripts" and "Scripts". So watch your capitalization and keep it consistent (lowercase is preferred).
    Thank you Irusak,
    So I changed ".Scripts" to ".scripts", that did the trick.. works great!!!
    (all-thought I do not understand why the "UpperCase" did not work, as long as I have UpperCase ".S" everywhere it should have been ok)
    Anyway thanks again for your help!!!
