In the meantime
Do a FRESH install with the wifi dtb. If you have already done that ignore me.
[SOLVED] 7.0.2.007 (s905) WIFI Working then Shuts Down. MiniM8sPro & other Devices
kostaman -
September 10, 2016 at 3:08 PM -
Was there any progress on this? I've not tried again in a while as I use ethernet but may need to use wifi soon.
Was there any progress on this? I've not tried again in a while as I use ethernet but may need to use wifi soon.I've installed a working SD Card LE 7.0.2.007 using the wifi fix device tree.
Current trees 22/9/16 device_trees
Then SSH ran command installtointernal
So i run Nand on my box. 7.0.2.007
Hope this is what you're after ?
This is also solved for my box.
Thought I'd tried the Realtek dtb, even had it downloaded but the file had 0 file size. Tried again and it works great.
