September 10, 2016 at 10:59 AM #1 hey,im the only one with audio delay/stutter/disconnects on bluetooth, when using the internal adapter from the PI? With an USB BT adapter, everything works fine.Is there maybe a fix for this problem?
September 11, 2016 at 6:16 AM Official Post #2 RPi3 wireless (both BT and WIFI) sullies the repuation of an otherwise great product. You already discovered the solution.
February 12, 2017 at 10:28 PM #3 The problem can also be solved by disabling internal wifi, as was explained in this forum:thread-2982.htmlthread-661.htmlMy search engine only showed this thread, that's why I'm adding these links here.
