jako, could you test this version?
LibreELEC.USB-SD.Creator.macOS-Sierra.dmg
I was told that in virtual machine Creator works. But maybe on real system it is something different.
Unfortunately still the "onvoldoende schijfruimte" error-message...
jako, can you make me screenshot of Creator app when you have USB reader inserted and selected card? I would like to see the text.
Good, now it is clear where the problem is.
Can you please try LibreELEC.USB-SD.Creator.macOS-Sierra2.dmg
Good, now it is clear where the problem is.Can you please try LibreELEC.USB-SD.Creator.macOS-Sierra2.dmg
Hi vpeter,
It Works! see attachments...
Thanks for fixing the Sierra-issue.
regards,
jako
jako, can I ask you for one more test: LibreELEC.USB-SD.Creator.macOS-Sierra3.dmg
Just need confirmation if still works.
jako, can I ask you for one more test: LibreELEC.USB-SD.Creator.macOS-Sierra3.dmgJust need confirmation if still works.
It still works, and a lot faster (writing speed of 8.x MB/s, the previous version 4.x)
jako, thank you very much for this tests. Yes, writing speed was the reason for this test - previously I have something disabled and to be 100% sure to still working I ask you again.
Next version will be published in next few days and will include also this fixes for macOS Sierra.
Thanks again.
I also can confirm that the fix working perfectly ![]()
vpeter, you're welcome!
If you need me to do any more tests, just ask.
However, next week I'm not able to test, since I'm at MacSysAdmin ![]()
Jako
Hi vpeter,
On 29 Sep you said the new version would be released in "the next few days". How is it going?
Jako
