Power saving suspends instead of shutdown
  • I have a 30 minute time out in the power savings settings. The option to switch between Suspend and Shutdown is dimmed out, but Shutdown is already selected. However, after 30 minutes my box doesn't shut down, it goes into suspend mode. The same thing happens if I press the power button on the remote, it goes into suspend instead of shutting down. I know LE is capable of shutting down the box, because I can go to the main menu an select "Power off system" from the shutdown options and it works as expected. I even tried enabling sleep.conf which disables the suspend function of the box. But with that enabled my box doesn't shutdown or suspend at all after the 30 minute time out is reached.
    All I want is for my box to shut down once the 30 minute threshold is reached. Does anyone know what's causing this issue or any ideas on how to fix it?
