Ok, I contacted you earlier in this thread regarding my PC with Libreelec on, where I wanted the power button to restart instead of shutting down. It's fixed as long as Kodi runs smoothly, but when Kodi hangs, the button doesn't work as intended. Kind regards, Thore
Shutdown with Power Button
movedoa -
February 8, 2019 at 7:19 PM -
Thread is Resolved
Hello!
I have a normal Logitech Harmony 600 and a Official Microsoft MCE receiver connected to my N100 Intel LibreELEC (official): 12.0.2 (Generic.x86_64).nano /storage/.kodi/userdata/keymaps/keyboard.xml
Variants like <power2> or Shutdown also do not work (after saving i reboot before testing).
It still just opens the Shutdown Menu.
What do i miss?
What do i miss?
Try the same on remote.xml with remote tag instead of keyboard.
Howdy, as Chewitt has told, since kodi is stuck it will not process any button presses, the setting thou is configured correctly because when kodi is running it will trigger the reset when the button is pressed.
In this case maybe having a dedicated reset button connected to the motherboard would be the best choice. That way your wife can manually press the button and give the system a hard reboot without you needing to connect via ssh.
Thanks for the tip, but i I have configured the button so that a long press causes it to reboot. Kind regards Thore
