Got a mxq s805 here got new version of libreelec installed but the controll that comes stander with android boxes wont work only usb keybord and mouse ?
Anyone help with remote ?
MickMakina -
August 31, 2016 at 9:15 PM -
You need the correct remote.conf for your box. If you still have android on the box you can copy it from there, otherwise it's search / ask / last option re-install android.
Once you get the remote.conf stick it in /storage/.config, reboot and it should work. -
Controller was working before installing over android ?
Yep, because you had the remote.conf in android.
So now you need to find it again (or worst case re-install android to get it). -
Right a get you now lol will give it a try but one. question how would i get it on to libree using ( putty ) or is there a easier way of doing it lol
Right a get you now lol will give it a try but once question how would i get it on to libree using ( putty ) or is there a easier way of doing it lol
Easiest way if you'r on a windows pc:
Open windows explorer.
Put
\\192.168.x.xx
in the address bar (with the real IP of your box).
A bunch of stuff pops up - the default smb shares from your box. Click on 'Configfiles' and you're looking at the contents of /storage/.config.
Paste remote.conf into there.
Reboot.
Cross fingers. -
Thanks for the help mate will give that a try tonight will let you know how i get on
Good luck. The only thing that can really go wrong is you stick the wrong remote.conf in. And all that means is your remote won't work, so no change.
Right a get you now lol will give it a try but one. question how would i get it on to libree using ( putty ) or is there a easier way of doing it lolI am using coreftp lite Free FTP client, secure file transfer software from windows
user root password libreelec obviously use your ip address or host name
see attachment
