Not sure if this is a libreelec or a kodi bug? I have libreelec 7.90.004 installed on a rpi3. All seems to be OK except for when I attempt to shutdown or reboot using a USB rpi remote. If I navigate to the home screen and select power options, it works as expected, HOWEVER if I use the red "power" button on the remote, it brings up the same "power options" splash BUT it is flashing on and off rapidly as if it's stuck in some sort of display loop. The functions "power off", "reboot", etc operate ok provided that the "enter" button on the remote is pressed when the window is visible, otherwise the "power options" window just disappears.
It's not a major bug, more of an annoyance.
