Hello,
I'm using libreelec 8.2.5 using this image on a mecool ki pro. The idea was to replace an old and bulky vdr box.
I tried the vdr addon that comes in the repository (2.2.0), but it doesn't work with dvbapi, the problem is exactly like this one (see also this dvbapi bug report).
Tvheadend works but
- it has problem tuning to some muxes (femon reports a stable lock)
- I prefer vdr because of a specific plugin I'm going to need.
I thought that maybe the problem was because of the old vdr version, so I managed to build vdr-2.4.0 (taking the recipes from libreelec master), but it still doesn't work
Now, according to the bug report I mentioned before, this is a problem with vdr, but the funny thing is that on the pc, with the same vdr version (2.4.0) and the dvbapi plugin (same git checkout) everything works fine
Another fun fact; the dvbapi plugin on x86 dynamically links to libdvbcsa, on aarch64 it doesn't (same Makefile
), though it doesn't complain about any missing symbol at startup, so I suppose it links libdvbcsa statically?
