No Sound / Audio Shutter one 8.2.4.1
  • Hello,
    i'm from Germany and this is my first post.
    I have Problems with no sound at all with passthrough oder audio stutter with pcm.
    I have a Minix u9 connected via 5G strong Wifi (no possibility to connect via gig lan), an sony bravia 8505c TV and a sony str 370 avr.
    The set up is: u9 Libreelec 8.2.4.1 installed on sandisk cruzer -> hdmi -> tv -> hmdi -> avr because avr cant handle 4k
    With a 4k DTS Movie i have no sound at all via passthrought and audio stutter via pcm. Whats the problem?
    i made a kodi.log hastebin
    Regards and thanks
  • The little I know you need to use correct HDMI port (ARC) between the TV & AVR and maybe even need to turn the Audio Return Channel feature on in the TV settings.
    That's the most I can help with as I have a different setup myself (HDMI->SPDIF passthrough).
