Hello everyone,
I have a weird problem with 4k hvec files, everything is fine with 1080p h264 files but when I play 4 hvec videos after a while colors constantly get higher and lower.
I don't know how to explain it properly, the video plays fine but after a while it gets jumpy like as if someone is playing with settings, colors are fine then they are too much then again fine then too much... it keeps jump too high and OK.
I have set the setting color to limited and it got a little better but then again it's not completely fixed.
I'm using hardware decoding, Prime, Direct to plane.
Also Prime EGL has no picture (its fine with 1080p h264 files), any fix for this?
and another thing would be using a rtc module with this board, i got DS3231 but dunno how to use it.
Thank you very much for reading this thread .
