Hi all,
I have a M8s Pro (S912 2/16). I am using LE 8.2.4 build. Before i went onto Ethernet I was using device tree gxm_q200_2g.dtb. This worked with wifi and the remote.conf I found on here for this box, and the remote worked fine. When i went to Ethernet, I found i could not connect, so used the gxm_q201_2g.dtb, and this allowed a wired connection. However, now the remote does not work at all, despite putting the same remote.conf file in place (same as before).
So, maybe I am still using the wrong device tree? I will need a wired connection, so cant go back to q200. Any ideas?
Thank you.
