Hi CvH,
I already saw that you did a image of Libreelec 8.0 for wetek.
Is 8.0 already final?
-zero-
Hi CvH,
-zero-
Hello CrazyCat
Vpeter prepared the LibreELEC (Krypton) v7.95.1 for Matrix ARM mini PC (TBS2910).
I would like use it with TBS7220 mini PCie card. Tbs released the Open source code for this TBS7220 pcie card.
How could I prepare the driver for this card on Matrix ARM with LibreElec?
Thank you
Hi CvH,I already saw that you did a image of Libreelec 8.0 for wetek.
Is 8.0 already final?-zero-
Hi all,
Id like to know if this is possible too, I have a Wetek Play 2.
Thanks in advance.
Hi cvh, any update on when 8.0 will be ready?
I'm really looking forward to the new skins and features. Is the update from 7 likely to be straight forward?
Is it correct that you cannot run the internal tuner and a USB tuner at the same time. Would this build help me have dual tuners?
if you are looking for TBS Drivers they are also at the official image
the other things will takes some additional days as it throws an error I can't fix yet
no this is possible, but depending at the hardware this could lead in driver conflicts
Really?! I've been using ljalves up to now, does the official have those?
I've relied on your support for my tbs card for so long. I'd be sad to move away from this thread
As I am responsible for the inclusion/fixing of the tbs drivers you have still to mess around with me
we use now GitHub - crazycat69/linux_media: TBS linux open source drivers
ljalves -> tbsdtv (official oss tbs drivers) -> crazycat (tbs + more)
sadly you have to use the official images (I am still building latest versions of this driver etc .. for my images)
that's double good news
I have a wetek play 2 - dvb-s2 and a dvbsky s960. I tried adding the firmware file, the logs show it detects it but not in tvheadend.
Where would I start to get this working or if you know what box I could buy that would run dual tuners?
like written at pm, not possible at the moment
What libreelec drivers should I be using for my dvbsky t982 T2 tuner?
DVBSky - Enjoy HDTV on PC! DVB-T2 / DVB-S2 Professional TV Tuner Card and Box for PC.
as far as i know the official LE image should work with that card !
Ok thanks, I'm using unraid with libreelec 6.3.2 it says my dvb adapter isSilicon Labs Si2168
I'm using a TV headend docker and I cant find any channels?
EDIT: Ok, removed old data and it connects. I backed up the old userdata. What can I copy across that will give me my channels and timers etc?
Update went ok, but tvheadend isn't connecting. Do I need to do anything to activate drivers, or delete old data? It says HTSP server is unreachable
I can't turn on timeshift in tvheadend.
I initially tried to update the filepath, and then couldn't save it. Now I can't enable and save...
Are there any settings I need to have a particular way?
no cards are found or ?
Maybe you have some card that isn't supported yet at Home · tbsdtv/linux_media Wiki · GitHub
if you just updated it shouldn't change anything, or did you used Tvh 4.0 before ?
I've managed to get tvh working as before, but I've lost my recorded programmes and timers.
Also, on the web config pages, I can't set any recordings, and my upcoming recordings etc aren't listed...
