Air Mouse Won't Work On Odroid C2 LibreElec Kodi Box
  • Hi, I'm brand new to LibreElec and I'm having a slight issue. I have it running, with Kodi, on an Odroid C2 and the program itself is running fine. I'm trying to use an air mouse with it. It's a Lepfun C120 Pro for anyone that wants to take a look. Right now it won't work. I've plugged in a wired mouse and keyboard so I know the USB's work but it won't read the air mouse. Not only will it not read mouse movements but it won't read the keyboard presses either. At one point it did connect but the connection was very poor and barely read any movment. Since then I get absolutely nothing. I'm really not sure where to begin in fixing this so any help is appreciated. Thank you.
    Edited once, last by MysteryGoat (August 10, 2016 at 9:15 PM).
  • LibreELEC on Odroid C2 is "officially" still very much in Alpha state, meaning things can either work not correctly, or not work at all. If it does connect, but poorly, perhaps your receiver is not of the best of quality. Or, batteries are low?
    Being precise on which LE builds (and whose) you are actually using is pretty important too. Several people in the community compile their own builds of LE, and anyone of those can have differences in them. It's a lil hard to vouch for someone else's compiling.
    Lepfun C120 Pro... Sounds like cheap variant of a Mele F10 Pro. I have yet to test my Mele remote on a S905 Wetek device, but once the LE build is ready I'm curious if it will work as well.
  • I'm using what looks to be the main build offered on the Odroid forums. But basically what I'm understanding is keep trying with each update and hope for the best? I knew LE was new but I didn't realize HOW new until a little research. So I guess I can't complain too much when something doesn't work right. At least the Kore app works flawlessly. Thanks for the help.
