Help- Cant power-on by ir remote on Le Potato (s905X)
  • I loaded Libreelec and configured the ir remote, all works well in Libreelec however when the system is powered off I am not able to power-on the system using the ir remote.
    Can anyone assist it how i could go about configuring the ir receiver to power on the system?
    The hardware I am using is Le Potato
    The software it is running is Libreelec 8.2.3.1
    Edited once, last by wyzco (May 15, 2018 at 6:13 PM).
  • If the Le Potato is anything like the RPi, once it is powered off - it is totally powered off. Only a hard power reset will reboot it.
  • this helped me on a tv box S905W with libreelec
    put the remote file into the bootable libreelec sd card you have made with win32
    and then select one of these remote files
    http://mxqproject.com/files/remote-config-file/
    put the remote file with the rest of your boot files on the sd card and try to boot the potato
    i dont know if you can short pin a le potato?
    on my S905W remote file 1 it worked but maybe you have to try more files never had problems with S905X
