Problem Android Keyboard
  • Good day, worth LibreELEC 7.0.3, manage through the Android application. When you click on a search in any of the plugins, the keyboard in the application itself does not open, on earlier versions, it worked.
    Now the keyboard appears in the application only if you manually press "Send media text to the center".
    How to fix?
    • Official Post
    It sounds like a bug in either the Android app or the Kodi XML-RPC api that mobile apps use to control Kodi. The only thing you can do it update to newer releases - all development on LE7/Kodi16 stopped ~2 years ago.
