Well, now i only copy start.elf and fixup.dat to SD card (replace the original) on #0629 release. i watch about 3-4 hour constantly and no reboot!
Random Restart on Rpi2 (8.2.4)
vamp -
April 5, 2018 at 7:38 AM -
Okay. You are on a Pi2, right? The commit I reverted should affect Pi3 behaviour rather than Pi2.
But, assuming you are still happy with the last test firmware can you try:
https://drive.google.com/uc?id=1ag88d56gimdzu7sxnc191hirepmgcnf8&export=download
This only partially reverts the commit to try to narrow it down. Let us know if you are happy or not with this version.
Yes, i use Pi2
I copy your new linked firmware (start.elf and fixup.dat ) but it restart again.
I hope it help you.
Hang on in there, I suspect popcornmix is either very busy (or hopefully enjoying the fine weather!) As/when time permits I'm sure there will be a follow up.
Hello Guys!
I saw that the new alpha is out!
Any change that it fix my problem? (it is include any bugfix or something?)
I don't think so, no. We still need to get to the bottom of whatever change is causing the restart on your board (and, it would seem, only your board!)
OK, thanks the info!
I installed the alpha but it randomly restarts. i copy the #0226 nightly firmware and it working well!
