My setup is minix U9 -> HDMI -> yamaha audio receiver HTR-2071 -> TV.
No sound when playing video files after enabling audio passthrough.
Can anyone help me how to fix this?
Have you selected all the audio formats in system settings Dolby Digital, DTS etc. ?
Let me guess, you are using LE 8.9.6 ?
Audio with the new AML Linux Kernel is problematic. No sound is a known problem.
Simply STOP using buggy Alpha Software and use the stable LE 8.2.x.x Kodi Krypton.
i have the U9 too, all passthrough works except DTS-HD MA, are the files your checking DTS hd ma?
sultanbrunei, you can try this LibreELEC-S912.arm-9.0-devel-1522058100.img.gz S912 test build based on 8.90.6 and check if audio pass trough works
this build doesn't have dvb
