Beelink, MINI, MXIII II and bluetooth on 8.2.3.1
  • Dear community.
    I am using the beelink box with kodi for a while now. Updated the builds here every now and then.#
    Basicaly it workes great without any glitches so far.
    Today i wanted to connect bluetooth headphones and saw that bluetooth is disabled.
    Wifi is working great on 5ghz btw.
    Systemlog
    WwO
    kodilog
    WwP
    Hope this is enough information.
    Thanks.
    derdigge
  • Hi i have two Beelink MINI MXIII II and i have no issue with bluetooth, did you you also install the newer Device Tree? Because it sounds like that you forget to use the newer Device Tree
  • i think, this is the one i used. just rechecked it now again on the sdcard i used few days ago.
    as i can not be sure i replaced the current one by: (nand installation)
    mount -o remount,rw /dev/system /flash
    wget -O /flash/dtb.img https://kszaq.libreelec.tv/s905/8.2/device_trees/S905X/gxl_p212_2g_nand.dtb
    dd if=/dev/zero of=/dev/dtb bs=256k count=1
    dd if=/storage/dtb.img of=/dev/dtb bs=256k
    Bluetooth is working now correctly. It looks like that i just used wrong dtb last time i updated. Thanks for pointing that out.
    Sorry for bothering arround here
