Ethernet and WiFi - WiFi will not connect on boot
    My system is using both Ethernet and WiFi to access to two different sub-networks. The Ethernet to VPN at 192.168.10.x, and the WiFi to local network at 192.168.20.x. The issue if that the WiFi will not connect on start. Manual connect works well.
    How can I force the WiFi to connect on start?
    Thanks,
    AlleyCat
