No Audio over Analog ( Jack OUT ) M8 s802 amlogic box
  • Hi to all firiends.
    i have this old m8 s802 box and would like to use in my bedroom.. i would like to use an external ( stereo ) amp.. this amp does not have any digital options as input so i need to use the analog output from this box..
    in android audio was always working.. but in non OE or LE versions i have seen this working..
    i hope some one is willing to help me out.. as i don't want to use any external DAC or other device..
    and of course i am willing to do anything what is needed to be done like logs or testing..
    Some info :
    LibreELEC-M8:~ # aplay -L
    null
    Discard all samples (playback) or generate zero samples (capture)
    default:CARD=AMLM8AUDIO
    AML-M8AUDIO,
    Default Audio Device
    sysdefault:CARD=AMLM8AUDIO
    AML-M8AUDIO,
    front:CARD=AMLM8AUDIO,DEV=0
    AML-M8AUDIO,
    Front speakers
    iec958:CARD=AMLM8AUDIO,DEV=0
    AML-M8AUDIO,
    IEC958 (S/PDIF) Digital Audio Output
    And :
    LibreELEC-M8:~ # amixer controls
    numid=1,iface=MIXER,name='Master Playback Volume'
    numid=5,iface=MIXER,name='Headphone Switch'
    numid=2,iface=MIXER,name='Headphone Volume'
    numid=18,iface=MIXER,name='Mono Output Mixer LEFT DAC Switch'
    numid=19,iface=MIXER,name='Mono Output Mixer LEFT REC PGA Switch'
    numid=20,iface=MIXER,name='Mono Output Mixer RIGHT DAC Switch'
    numid=6,iface=MIXER,name='Capture Switch'
    numid=14,iface=MIXER,name='Playback digital mixer'
    numid=29,iface=MIXER,name='Ext Spk Switch'
    numid=30,iface=MIXER,name='HDMI Audio Type'
    numid=8,iface=MIXER,name='High Pass Filter Switch'
    numid=16,iface=MIXER,name='Left LINEIN Select'
    numid=24,iface=MIXER,name='Left Output Mixer LEFT DAC Switch'
    numid=25,iface=MIXER,name='Left Output Mixer LEFT REC PGA Switch'
    numid=26,iface=MIXER,name='Left Output Mixer RIGHT REC PGA Switch'
    numid=7,iface=MIXER,name='MIC PGA Switch'
    numid=4,iface=MIXER,name='MIC PGA Volume'
    numid=12,iface=MIXER,name='Noise Gate Switch'
    numid=11,iface=MIXER,name='Noise Gate Threshhold'
    numid=13,iface=MIXER,name='REC digital mixer'
    numid=3,iface=MIXER,name='Record Volume'
    numid=17,iface=MIXER,name='Right LINEIN Select'
    numid=23,iface=MIXER,name='Right Output Mixer LEFT REC PGA Switch'
    numid=21,iface=MIXER,name='Right Output Mixer RIGHT DAC Switch'
    numid=22,iface=MIXER,name='Right Output Mixer RIGHT REC PGA Switch'
    numid=31,iface=MIXER,name='SPDIFIN Audio Type'
    numid=9,iface=MIXER,name='Wind Filter Frequency'
    numid=10,iface=MIXER,name='Wind Filter Switch'
    numid=27,iface=MIXER,name='aml audio i2s mute'
    numid=28,iface=MIXER,name='aml audio spdif mute'
    numid=15,iface=MIXER,name='i2s1 digital mixer'
    Thank you all in advance ...
    Edited once, last by Mr Ozzy (January 24, 2018 at 12:50 PM).
  • Our 3.10 kernel has been hacked enough to make HDMI and S/PDIF work properly but analogue audio was not a priority. There are no plans to go back and fix that among any of the staff devs. Community contributions are welcome.
