Hello all,
i was installing Libreelec on my Intel Compute Stick (STCK1A32WFC) but for some reason there is no WIFI. Is there an Issue with the Wifi? Couldn't find help on the internet about that. Thank you for your help..
Best
Mehmet
Hello all,
Best
Mehmet
Can you get "journalctl -a" from the device?
blueribb The problem is that without the required information - at least journalctl, ideally the latest zip file from the Logfiles Samba share, as explained here - we don't know for sure what the problem is - it could be missing firmware, or a missing driver.
The article you linked to (thanks for that) claims the WiFi chipset is RTL8723BS which is now supported by the in-kernel driver in LE9.0 nightlies (but not LE8) so it might be worth the OP giving LE9.0 a try - test builds are here.
